1.0.13
- Add chartingSize to the Chart interface, giving the Size of the charting zone
1.0.12
- Workaround performance issue (that could lead to long webpage-wide freezes) caused by slow
ArrayList.addAllon Kotlin/JS KT-57607 - At least 2x better rendering performance
- Improved highlight on hover performance. Noticeable on charts with many elements
- Deprecate
performanceMode: the optimizations it was enabling are now always on - Several general fixes, many fixes for iOS, and some fixes for Android carried from Data2Viz releases 0.10.2 to 0.10.5 included
- Other internal improvements
- Compiled with Kotlin 1.8.10
1.0.11
- Upgrade to Data2Viz version 0.10.1
- CHRT-252 Optimize the calls to computeLabelSpaceAndRotation (CHRT-252)
- CHRT-199 The chart refresh function is now public (CHRT-199)
- CHRT-249 Intoduce the applyZoom function (CHRT-249)
- CHRT-250 Platform is now public, user can handle platform-specific code (CHRT-250)
- Events listeners functions can now stop or propagate the base event
1.0.10
Stable release of previous 1.0.10-RC1
1.0.10-RC1
- Use Kotlin v 1.6.21
- Use Data2Viz 0.10.0
- Change KPointerEvents values with new objects
- Fix an issue when using “pinch to zoom” with very small values
- Fix an issue when using “selection to zoom” with a very small selection
- Added the EventType.Fling and manage it in the default getChartActionOnUserEvent
- Add the pinch gesture to trigger zoom/pan in a same movement
- Unify touch and mouse events in the event controller
- Unify EventContext and UserEvent classes
- Rework EventContext based on the D2V events changes
- Create a new EventType : Cancel: hide selection for the defaultChartActionOnUserEvent
1.0.9
- The selection now remains after a zoom/pan (CHRT-244)
1.0.8
- All the selection events now implement the SelectionEvent interface
1.0.8-RC7
- Add more documentation on the ChartController interface
- Add missing documentation on the ZoomAction class
- Fix an issue with missing / empty labels on the DefaultAxisRenderer
1.0.8-RC6
- Introduce the PanAction and ZoomAction data class
- CHRT-211 Deprecate the “ticks” variable (CHRT-211)
- CHRT-209 Major optimization on the computeLabelSpaceAndRotation function (CHRT-209)
- CHRT-241 EventContext now handles the zoom and pan constraints defined by user (CHRT-241)
- CHRT-243 Handle specifically the selection zoom (CHRT-243)
- CHRT-124 New behavior for ZoomMode.XY, you can now zoom in X-only, Y-only or XY with the same movement (CHRT-124)
- CHRT-234 First implementation of a “smart layout” tooltipBuilder that takes the global size into account (CHRT-234)
- CHRT-176 Make the title of the tooltip user-configurable (CHRT-176)
- Remove the bindCursorOn property as it is managed by the getChartActionOnUserEvent lambda
- Rename clearSelection to hideSelection for clarity
- Small refactoring of the zoom algorithm for clarity
- Hide selection when clicking, wheeling and dbl-clicking
1.0.8-RC5
- Introduce the getChartActionOnUserEvent lambda to customize any event control
- Introduce the SelectedDatum class to get more information about a selected sign
- Add several performance improvement and lazy inits
1.0.8-RC4
- The BoxPlot now has its own experimental decorator
- CHRT-232 Fix an issue where a custom cursor is not refreshed when zooming/panning (CHRT-232)
1.0.8-RC3
This version uses the latest 0.9.1 version of data2viz. Data2viz is now released on maven central and has a new prefix in front of each artifact. If you want to add a dependency on a data2viz module you should do it with the prefix d2v. For instance:
io.data2viz.d2v:d2v-random:0.9.1
- CHRT-229 Fix an issue where selection was cleaned after a highlight (CHRT-229)
- CHRT-213 You can now force to use bandwidth on any discrete axis (CHRT-213)
1.0.8-RC1
- use data2viz 0.9 with JavaFx 11,
- chart size does not change vizContainer size.
1.07 and 1.0.7-RC7
- Fix an issue when displaying a Boxplot with shape Hourglass and no mean value
- Tooltip customisation is now accessible via the tooltipBuilder lambda
1.0.7-RC6
- RichTextBuilder.
1.0.7-RC5
- CHRT-224 mobile events: does not use density anymore. fix endTouch without move. (CHRT-224)
- CHRT-223 : don’t recompute eventZones for LineMarkImpl and AreaMarkImpl.kt (CHRT-223)
1.0.7-RC4
- CHRT-206 Automatic control of the density of the gridlines (CHRT-206)
- CHRT-212 Improve the BoxPlot mark (CHRT-212)
- CHRT-215 Cursor improvements (user control and data aware) (CHRT-215)
1.0.7-RC3
- CHRT-219 Manage series in boxPlot (CHRT-219)
- CHRT-217 Make the event cancelable by the user (CHRT-217)
- CHRT-216 Add the possibility to add/remove elements from a selection (CHRT-216)
1.0.7-RC4
1.0.7-RC3
1.0.7-RC2
- upgrade to kotlin 1.5.31, data2viz 0.8.15
1.0.6
- AxisRenderer: fix the labels rotation for very small axes (CHRT-173)
- Cursor: you can now use a custom cursor decorator (CHRT-191)
- Marks: add the possibility to customize the “event zone” (CHRT-193)
- Zoom: fix the zoom ratio with selection zoom when selection is null (CHRT-195)
- Zoom: fix the zoom ratio with mouse-wheel zoom (CHRT-196)
- AxisRenderer can decrease size or rotate labels if needed (CHRT-198)
- Chart: create a refresh function (CHRT-199)
- LineMark: use the SelectionDecorator (CHRT-186)
- Highlight/selection: can now be defined for each mark (CHRT-185)
- Configuration: fix delegation of Stroke and Font properties after a copy (CHRT-183)
- Performance: better performance when using Symbols (CHRT-184)
- PlotMark: the “plot mark” is now called a “dot mark”, the plot() function has been deprecated.
1.0.5
- using data2viz 0.8.12
1.0.4
- Marks: deprecate the symbol & showSymbols property, replace it with marker & showMarkers (CHRT-177)
- Axis: the axis bandwidth is now determined automatically depending on the marks used in the chart (CHRT-133)
1.0.3
showSymbolsproperty, replace it with marker &showMarkers(CHRT-177) - Axis: the axis bandwidth is now determined automatically depending on the marks used in the chart (CHRT-133)
- Title: center the title, considering the whole size of the chart, not just the main charting zone (CHRT-175)
- Pan: fix an issue where scrolling (pan) to the origin position was not effective (CHRT-174)
- Double formatters: fix an issue where negative numbers were not rounded like the positive ones (CHRT-172)
- Line: fix an issue where the last segment of a fractionated line was missing (CHRT-171)
1.0.2
- Chart: the background color can now be set at runtime (CHRT-170)
- Area: stacked area with missing categories: a warning message now informs the user the dataset is incomplete (CHRT-157)
- BarMark: the “position” property of the DatumDecorator(s) are now at the center of the “top” of each bar (CHRT-163)
- LineMark: fix an issue when the last point of the line was missing or null (CHRT-169)
- Axis: add fixed rotation for labels, the property is “labelRotation” (CHRT-161)
- Axis: increase readability by using a different text alignment depending on the rotation (CHRT-160)
- Axis: improve the DefaultAxisRenderer: more precise sizing, rotating labels, better smart layout (CHRT-150)
- Axis: fix issue, setting an Axis title through the DSL is now possible and overrides the Dimension’s name (CHRT-153)
- AxisConfig: deprecate the axisLabelLayout & discreteTickSkip properties as axes now use smart layout (CHRT-159)
- Cursor: mode “Auto” now gives the priority to “discrete” axes (CHRT-154)
- Cursor: change the default color to 50% alpha (CHRT-152)
- Title: the title padding is now effective (CHRT-165)
- Tooltip & Legend: these 2 components now manage “Labelled” elements (CHRT-149)
- EventController: the highlight/selection feedback is better for “row” and “column” mode (CHRT-146)
1.0.1
Fix #CHRT-145: Legend not displayed before highlight.
1.0.0
package name changed: the main packages changed from io.data2viz.charting to io.data2viz.charts.
SizeManager : To instantiate a SizeManager (interface) you now need to call sizeManager() instead of the previous direct constructor call SizeManager().
Configuration: all the configuration overrides are now in a config lambda inside the chart.
0.8.4
viz: add newVizContainer that adds a viz container as a child of body (for play.data2viz.io).
