Hello,
We are getting NoSuchElementException where there are no samples in the chart.
We tried this java also, and the following is the stack trace,
Could you please help us here?
Exception in thread “JavaFX Application Thread” java.util.NoSuchElementException
at io.data2viz.charts.axis.internal.DefaultAxisRenderer.computeLabelSpaceAndRotation(DefaultAxisRenderer.kt:140)
at io.data2viz.charts.axis.internal.DefaultAxisRenderer.getSize(DefaultAxisRenderer.kt:72)
at io.data2viz.charts.chart.internal.ChartImpl.getPreferredDisplayZone$core(ChartImpl.kt:165)
at io.data2viz.charts.chart.internal.ChartImpl.(ChartImpl.kt:866)
at io.data2viz.charts.chart.ChartKt.chart(Chart.kt:40)
at io.data2viz.charts.chart.ChartKt.chart$default(Chart.kt:35)
at com.camline.space.chartskt.common.SpaceChartKt.createChart(SpaceChart.kt:148)
at com.camline.space.chartskt.SpaceMainJvm.addChart(SpaceMainJvm.kt:484)
at com.camline.space.chartskt.SpaceMainJvm.updateCharts(SpaceMainJvm.kt:438)
at com.camline.space.chartskt.SpaceMainJvm.showChart(SpaceMainJvm.kt:387)
at com.camline.space.chartskt.SpaceMainJvm.start$lambda-30$lambda-29$lambda-28$lambda-27(SpaceMainJvm.kt:138)
at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
at javafx.event.Event.fireEvent(Event.java:198)
at javafx.scene.Node.fireEvent(Node.java:8411)
Many Thanks!
